'65 Chevy C-10 rebuild.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-19-2009, 07:03 AM
World's Worst Mechanic
Need tips on building up my '65, lots of questions. Where can I get parts to convert to Turbo-350 tranny, any tips on rebuilding or manufacturing roof patches, disk-conversion techniques, floor repair guidance, any knowledge for this particular model, questions as to which 4-barrel to use with my 350stroker, header fits, and anything likely to be missed in a once-over of the truck..
Old 01-20-2009, 03:13 PM
On the learning curve.
First tip- Take it one step at a time. Pick one or two of your questions above and elaborate. For instance, focus on drivetrain. Give the exact engine setup you will have if you want to know carb size. If you want to know about trannys make sure you give the particulars, engine, tranny, rear gears, tire height, vehicle weight etc should help figure out what torque converter you'll need etc.
If you jump all over the place you'll never get the info your looking for as well as you'll have a hard time building the truck that way, believe me I made that mistake once.
Steve
FIT 10 bolt 78 and 65 Alan Byers Suspension - Brakes - Steering 2 11-29-2007 04:49 PM
Brake lights switch oldsmo Electrical 4 10-19-2006 11:23 AM
C-4 65 Mustang Tranny Rebuild 65Mustang289HIPO Transmission - Rearend 13 05-02-2006 12:47 PM
72 chevy rebuild HalfCutSkeleton Engine 3 01-22-2005 10:23 AM
Rebuild kit for a 1950 chevy 87 hp spikes_50 Engine 2 05-20-2003 12:42 PM
