65 Chevy Fleetside P/Up rearend is old.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-26-2007, 07:46 PM
CustomConspiracy's Avatar
I have a 65 Chevy Fleetside P/Up. I have removed the older 6cyl that was in it, and dropped in a 283. I replaced the TH 350 with a newer 700R-4 trasns.
I got all the TV cable stuff.......drive shaft is shortened......even got the little valve thinngy that makes it so it won't shift out of OD at cruising speed unless you push 3/4 pedal.
I am not concerned with nose bleeding speed......or smoke shows....but I am a Pin Striper/Airbrush/ Fancy Paint kinda guy and I wanna drive this thing to a lot of Rod Runz and shows.....and I need good mileage more than anything.
Soooooooooo....Waddiyathink........is gonna be the best rear end ratio to run?
The original rear end is in it. I have NOT opened it up to count and figure what is in there.
It may turn out that I eventually go for disc brakes all the way around. Does anyone have any good ideas for what to look for as a transplant?
It has coils all the way around........and is dropped a few inches nut not notched.
This is NOT a show truck. It's my Shop truck and daily driver.
Old 12-26-2007, 08:25 PM
31 five window
Last journal entry: grill and rear end
65 chevy
You do not have to take it apart to see gear ratio. Jack it up and put on jack stands. Put it in neutral. Get a friend you trust and turn each wheel so valve stem is down. Then mark pinion yoke and housing where you can see it while turning the wheels. You each take a tire and turn in the same direction as if you had posi exactly 1 revolution and Count how many times the yoke mark passes the housing mark and thats your ratio.Example, 3 and 3/4 turns = 3.73 gears. We built a Bad big block 65 out of an original 6 cyl 3 on the tree and used the stock rear end. We narrowed it 5" on each side and added posi.
Old 12-27-2007, 12:07 AM
JeffB's Avatar
65 Rear end
Almost all the 65 C-10's had 4.10 rear gears,mine had a 6cyl 3spd originally too,when I got it it had a '78 Camaro 250 6cyl & 350 trans,I swapped out the 6 for a built 350 at 70mph it was cranking 3500 rpm I changed to a 700R4 and cruised at 2600 rpm. That was a big improvement! But if you run shorter profile tires a 3.55 ratio would be better.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
chevy truck rearend swap OldSkooLNewbie Transmission - Rearend 0 01-18-2006 09:07 PM
Chevy rearend Chevydude Transmission - Rearend 3 05-13-2002 01:10 PM
How Strong is a Chevy 10 Bolt Rearend bigjoedo Transmission - Rearend 3 04-07-2002 05:04 PM
308 chevy rearend norms37chevy Transmission - Rearend 4 02-07-2002 06:21 AM
