Start a wiki article on any hotrodding subject:
Then, others help to build it.
Read and write hotrodding articles in the Crankshaft Coalition Wiki.
See 150+ articles, or read The 8-sentence guide.
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 01-31-2008, 09:16 PM
dar130 dar130 is offline
'65 chevy P/U drop spindles or coil spring change?
Have a '65 chevy P/U, SWB, needing help with the choice of dropped coil springs front and rear or dropped spindles on the front
What will be the difference with spindles verses springs on the front?
Knowing with dropped spindles disc brakes will be needed
Darele
Old 02-01-2008, 05:59 AM
1ownerT's Avatar
1ownerT 1ownerT is offline
1ownerT's barnstarLast wiki edit: Building a new shop
Wiki Edits: 2
Installing drop spindles retains the full suspension travel and maintains the stock geometry. Typically when dropped with springs the camber is affected, some vehicles this can be compensated for with an alignment, others do not have the adjustability to get it back where it should be.
Old 02-01-2008, 08:55 AM
66chevystepside's Avatar
66chevystepside 66chevystepside is offline
I agree with the dropped spindles... I put 73-87 dropped spindles (for ease of disc brake conversion before they had the easy kits) on my '66 stepside and am very happy with the results.
Old 02-01-2008, 05:58 PM
might you explain the easy kit ?
thank YOU
Old 02-01-2008, 07:18 PM
Chevrolet4x4s Chevrolet4x4s is offline
Chevrolet4x4s's barnstarLast wiki edit: How to title a hot rod
Use of 73-87 stuff would be cheaper than a kit. Theres a complete front suspension/brakes for a 2wd 86 in the paper for 50bucks.
Shane
Old 02-02-2008, 09:54 AM
There are disc conversion kits out there that use the stock spindles to give you a simple disc conversion... Then you would probably have to go with shorter springs to get the lowering - you are way better off with dropped spindles to retain the suspension travel.
thank YOU
Old 02-02-2008, 10:27 AM
understand now,,, Thank YOU !!
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "'65 chevy P/U drop spindles or coil spring change?"
HELP….HELP info on Moog coil spring, Im running iut of time 406chevelle Suspension - Brakes - Steering 7 04-25-2004 08:39 AM
Coil Spring Movement Dave E Shank Suspension - Brakes - Steering 9 03-26-2004 06:36 AM
67-72 drop spindles chevyman17 Suspension - Brakes - Steering 2 05-01-2003 04:40 AM
Drop spindles for 1951 chevy lgsteelhead Suspension - Brakes - Steering 2 01-02-2003 05:58 AM
ignition/coil wiring 72 chevy p/u icegnome Electrical 2 12-21-2002 04:59 AM
