65 chevy pickup - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2010, 01:49 PM
65 chevy pickup
help on this wont charge up got new battery volts altanator what else can be wrong here
Old 09-20-2010, 03:39 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Look carefully for a burned "fusible link". This is an insulated wire of a smaller gage spliced into a wire. It acts as a fuse and will melt before the larger wire is damaged.
Follow the wires from the alternator to where they end, you may have to feel and/or slice the tape or plastic loom off of the wiring harness to see them clearly and to locate any fusible links.
Another thing to check, is to be sure the ground wires are intact and making good contact. There should be a ground cable from the battery, also smaller ground "straps", as they're called, between the firewall and the engine, and from the engine to the fender well sometimes, and sometimes from the battery terminal at the battery to the fender well.
Let us know.
Old 09-22-2010, 07:29 AM
65 Chevy
Have bought everything battery alternator,starter,but it's still discharging please help me,what else could be wrong even took it to a computer said it was the volts bought it still discharging,
Old 09-22-2010, 08:05 AM
ericnova72's Avatar
More for Less Racer
Voltage regulator been checked or replaced??
Old 09-22-2010, 11:02 PM
65 Chevy
Anyone Knows Where Can I Find A Diagram For My 65 Chevy Looking For My Wiring
Old 10-06-2010, 02:27 PM
35terraplane's Avatar
chev dis charging
Well if it shows discharge, and everything is off, with engine running, you have a short to ground, or the wire from the Alt. To starter is Shorted, I don't think they used a fusible link back then, but I believe they still had a voltage regulator. I would guess that it is bad giving you a discharge reading. Does that have a voltmeter or a ammeter?
35terraplane
Old 10-06-2010, 07:03 PM
T-bucket23's Avatar
Wiki Edits: 26
Originally Posted by 35terraplane
Well if it shows discharge, and everything is off, with engine running, you have a short to ground, or the wire from the Alt. To starter is Shorted, I don't think they used a fusible link back then, but I believe they still had a voltage regulator. I would guess that it is bad giving you a discharge reading. Does that have a voltmeter or a ammeter?s
35terraplane
They did use fusable links. If it is original it also has an external regulator. You can try running a jumper from the field terminal on the alternator to a 12 volt source to see if the voltage comes up. If it does then you know the alternator is working. It could go as high as 16-18 volts so dont leave it attached.
There are several threads on here about the old external regulated alternators and there wiring
Chet
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Chevy 350 Engine & Trans in a 46 Chevy Pickup Warner Engine 4 02-11-2005 04:44 PM
Headlights for my 54 Chevy Pickup horvath Electrical 11 01-10-2005 07:15 AM
Windsheild Wipers & Arms for 54 Chevy Pickup horvath Body - Exterior 2 04-06-2003 08:29 AM
Windshield Frame for '54 Chevy Pickup horvath Body - Exterior 5 03-31-2003 05:07 PM
