65 chevy timing trouble - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2009, 08:58 PM
SonnyFaust's Avatar
i have got a 350 and i need to know how exactly to set the timing. if i turn the distributer back towards the cab it will idle good but the valve will chatter driving down the road. if i turn it the other way it will idle very poorly but will drive ok. i dont know alot. So detailed help will be much appriciated. it has a crome timing cover. so i bought a timing tab and dont know where to bolt it up. and i appriciate all advice givin. thanks sonny also it is electronic ignition. if that matters.
Old 06-14-2009, 04:42 AM
by chatter I'm assuming pinging.What is the base timing at now? Did you use a timing light? 8 degrees btdc is a good starting point for most small blocks with stock cams.
Old 06-14-2009, 09:17 AM
SonnyFaust's Avatar
yes pinging. its bored 30 over with a 272 cam.
Old 06-14-2009, 12:03 PM
I would still start there and work your way up to the point it pings and then back off 2 degrees this will be a good ball park.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Timing question for 1996 Chevy Vortec SRSingh Engine 1 05-31-2007 02:27 PM
1987 chevy tbi timing? hiball Engine 1 04-19-2007 02:10 PM
Small block chevy timing Anton Engine 1 06-16-2005 10:27 PM
Timing Specs for chevy 350 engine 68_Convertible Engine 3 11-25-2002 05:51 PM
