65 chevy truck to 70 chevy truck frame - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2011, 12:17 AM
I have a 65 chevy long bed and a 70 long bed was wondering if the 65 body would bolt up to the 70 frame without moving any of the body mounts.
Old 05-25-2011, 10:20 PM
The same frame was used from 1960 to 1972. Yes it will bolt on.
Old 05-25-2011, 10:22 PM
Thank you very much for the info
Old 05-26-2011, 01:27 PM
ogre's Avatar
the 'Duracell Project'
it's a chevy, everything fits on everything
Old 05-27-2011, 09:39 AM
63-72 is definitely the same. The only difference is going to be ball joints, spindles and disc brakes and frankly... all of that stuff is interchangable. The early sixties trucks used a torsion bar front end. Now you can take the 63+ crossmember and put it in a pre62 with some slight mods. 73+ uses the same exact crossmemeber but the frames themselves did change.
59 Chevy truck body on 80-85 Chevy frame? texczech General Rodding Tech 11 08-18-2011 09:24 PM
Help! what frame to put under a chevy 1 1/2 ton truck? Riley Hotrodding Basics 10 02-15-2009 09:15 AM
will a 40 chevy truck fit on a S-10 frame 71corvette Hotrodding Basics 11 12-07-2008 08:39 PM
Subing Nova frame into a 1957 chevy truck frame crshields90 Suspension - Brakes - Steering 1 02-02-2008 10:15 PM
s 10 frame under a 52 chevy truck coyote069 General Rodding Tech 3 09-23-2003 09:04 PM
