'65 Chevy Truck lighting
Are the amber markers in the hood supposed to be on when the head lights are on?
They flash normally when the turn signals are used and light up continuously when the 'parking lights' are on, but are off (except when signaling) when the headlights are on. It's a new addition to my fleet, and I'm not totally familiar with them. (60-66) Thanks |
Turn signal / parking lamp
Nope... They are only on with the parking lamp (Switch pulled out 1 click) or when the turn signals are in use. The lamps are off when the headlights are on (2 clicks out on the switch.) That is their design.
Love these trucks!!!!!
Re: amber markers
If you want them on with the headlights its easy to change the bulb sockets to 1157 2 element styles then pull power off the headlight switch, but rember to tap in before the dimmer switch so they will always have power when the headlights are on.
While you are at it you may want to add some relays for the headlights, the 66 wires have a tough time pulling enugh power for today's halogen bulbs, I know on my panel it made a lot of difference. One last thing if you tire of the amber lights there the 62-63 used clear ones with amber bulbs. They will fit the 64-66 and could be lit with other colors for off road use only of course clear parking lamps Brian kc0kfg |
As always, thanks for the replies. |
Re: amber markers
doh! thats right ..... Its been a while since ive looked at an org harness for my truck I run all 88 c/k wires on my 66 so i could keep the F.I. and the ecm controled 700r4 Brian kc0kfg |
me again
Old thread, I know.
Thought I'd post up a 'fix' of sorts while it's on my mind. I was wanting the amber hood markers to be on when the head lamps were. I think it adds a little character. Simple fix. Remove the head light switch, remove purple wire from the plastic plug. (terminal #7) The purple wire runs to the low side of the 1157 bulbs in the hood markers. The switch is marked with numbers beside each terminal. There is an unused terminal on the switch and a provision for it in that same plastic plug. This is terminal #3. Slide the purple into this terminal #3 spot making sure it clicks into place. An extra measure of safety at least. I should write a WIKI, but I haven't a clue. |
| 1955 Chevy Truck | Streamline55 | Introduce Yourself | 4 | 12-06-2007 07:22 PM |
| More Chevy Truck Operator's Manuals ONLINE! | khardy | General Rodding Tech | 4 | 02-01-2007 10:27 PM |
| Car 235ci into '53 Chevy Truck | New2theart | Engine | 8 | 10-17-2006 12:37 AM |
| 53 chevy panel truck | huligar | General Rodding Tech | 12 | 04-27-2006 03:53 AM |
| 94 chevy truck maybe dist./ignition problem,please help! | bluesmanjesse | Engine | 14 | 11-19-2004 03:31 PM |
