65 F100 chassis swap... - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-20-2012, 09:50 PM
carsonGs's Avatar
Chris
I have started my 65 F100 Im going to do a chassis swap with a crown vic chassis.I will post pics as the build goes along any (HELPFUL) Tips,tricks,and other info is more than welcome. If you think this is a bad idea or just dont like the idea of a chassis swap PLZ dont post. I have seen other forums where people have posted negative comments and im not that type of person. Not so much on this site thats why I sign up here thanks I hope i didnt come off to harsh.
Old 12-20-2012, 10:42 PM
Wiki Edits: 27
crosssmember?
I've seen info on the ford truck forums about swapping in a C Vic crosmember, not the whole chassis. and a few guys have done the Jag front and rear. And a couple ford Aero star crosmember swaps.
Old 12-20-2012, 10:48 PM
carsonGs's Avatar
Chris
yeah me too I was going to go with s10 frame then I seen a post on a crown vic
im not sure if it was on here or not he had full pics of the whole build looked awesome and they even used the engine and trans out of the vic.... first time I seen that i think it was like a 97 chassis also seen one on like a 86 or 87 ltd frame pretty much the same as the newer vic... with factory height of the vic it had the perfect stance im the type that likes to try new things hard or not...
Old 12-20-2012, 10:59 PM
carsonGs's Avatar
Chris
Its on slick60s its a 62 f100 on a 87 crown vic frame.
Old 12-21-2012, 07:18 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
That particular chassis swap makes a lot of sense to me..Now it will be some work in fabbing the body mounts and such..and wheelbase is something to look at but then altering the wheelbase of the chassis is not overwhelming..
Sam
Wiki Edits: 3
Sam
Old 12-21-2012, 09:12 AM
gearheadslife's Avatar
MentalMuffinMan
I'd add plate to the frame center, as it'll not have a full body to help with strenth..
iirc my '99 the frame is boxed.. most use the '04 up with alum front set up..
Old 12-21-2012, 12:39 PM
carsonGs's Avatar
Chris
yeah I believe its going to come out good The suspension and ride quality is what im truly after with the swap. have any of yall done a similar build.
302 F100 swap? lizardking7750 Engine 15 01-19-2011 08:40 PM
56 F100 on to S10 or Ranger chassis 56man General Rodding Tech 8 05-11-2008 08:20 PM
56 Ford F100 to a S10 Chassis? Phillfam99 Body - Exterior 12 02-22-2008 07:43 PM
63 F100 Engine Swap 69SS396375HP Engine 7 04-24-2007 09:53 AM
53 F100 5.0/T5 swap? 68c10owner General Rodding Tech 6 01-07-2007 06:01 PM
