Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 65 Ford F100...Biggest Engine without Cutting
Old 09-13-2012, 10:03 AM
matt167 matt167 is offline
Wiki Edits: 31
The sky is the limit. If using factory parts you can go to a 427 in an FE platform, 429/460 in a 335 platform or any type of stroker in between, and because Ford used FE's and 335's in that chassis, it is a bolt in affair. Cad 472/500 would be cool too.
