I'm definently going to take my time. I'm making 2 different "budgets". One will be with "new" or special built parts (engine/tranny, etc.) the other with "used" and picked parts. I'm a very meticulus person, and very persistent also. I'll be giving myself a 2 year window to do the build. Ya'll don't know this, but I'm a disabled Veteran, so I'm home about 90% of the time. No problem as far as my time restraints are concerned. I'm pricing used Caddys and LTDs as well as pricing new. Learning a lot and enjoying the hell out of it....and I haven't even put wrench to bolt yet. Thanks again for all of the advice guys and gals, I really do appreciate it.
460 oil filter.
I don't know about your your oil filter, clearance issues. The FE factory filter casting for trucks pointed the filter sideways, the car filter points down. Ford Vans with 460's have a filter mounting casting that you can rotate as needed for more clearance, the van casting will work on anything that uses a ph 8A oil filter, mabe even and some Mopars that use Ford Filters. Some Heavy duty 460 vans and trucks also came factory with an engine oil cooler. If you get a 460 the first thing you want to do is get a double rolller timing chain kit and install it straight up. Factory smog years retarded the stock cam and lost about 30 HP.. the stock timing chains stretch and retard ign and cam after 10 to 20 K miles. A 460 single diaphram distributor vacuum can is adjustable. pull the hose and insert an 1/8 allen wrench to fine tune the advance.
budget suspension
There ar quite a few F 100,s with Jaguar XJ 6 suspensions, easy to swap in the front and rear suspension crosmembers, I have bought Jag setups for $ 100-125 we pull. do more searches for step by step info on various web sites. ( F100 jag suspension) (jaguar suspension swap)
| '59 Ford F100 Pickup with Buick engine | birdman1 | Introduce Yourself | 5 | 11-14-2010 04:23 PM |
| What's the biggest engine that would fit a 94 firebird | Amyzblueeyez | Engine | 5 | 04-11-2006 09:00 AM |
| Biggest single cylinder engine? | udu56 | Hotrodders' Lounge | 14 | 03-29-2006 02:08 PM |
| Biggest Hemi Engine | Silentlion_69 | Hotrodders' Lounge | 9 | 12-18-2004 12:23 AM |
| biggest, most powerful engine | cadillac man | Hotrodders' Lounge | 36 | 08-04-2004 11:10 PM |
