65 ford pick-up? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2008, 02:09 PM
65 ford pick-up?
i was offered a 65 ford pick-up that has a 'ran when parked' 360c.i. and a 460 two barrel carb on top. it was an auto. and has a good rear-end.
now, may ?s are can this motor bolt to a tranny that a 302 is bolted to it?
and would this truck have a 9 inch in it?
im not real educated on what will bolt to what with fords. so any help is appreciated.
Old 06-21-2008, 02:15 PM
302 (all W and C engines), 360 and all FE engines, and 429/460/351M/400M each series have unique transmission bellhousing bolt patterns.
65 1/2 ton pickup will have a factory 9 inch rear end.
FYI 65 pickups did not come factory equipped with 360 engines. 352 or 390 yes.
Old 06-21-2008, 02:37 PM
thank you, so i need to run the numbers on the block to fin out for sure what it is. put for $500. it will be worth it for the rear-end alone.
Old 06-21-2008, 03:57 PM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
From 57 to 72 the 9" rear ends are narrower than the later ones.
I know you can pick up these for around $200 (lot of guys on another site have). There are a lot of them around. I traded some junk chevy parts for one. Although I have never put it in.
I would not pay $500 for the rear end alone.
If the body is pretty straight (not rusted out), it is worth it I would think. You can always part it out and sell the rest for scrap.
Assuming you don't drop a drivetrain in it and drive it as is.
Lowering a 1960 Ford Pick up rushlow Suspension - Brakes - Steering 2 11-14-2011 11:27 PM
chop 1932 ford pick up wizard1932 Body - Exterior 3 05-18-2009 08:28 PM
51 Ford Pick Up mercury man Transmission - Rearend 4 03-22-2008 03:44 PM
1979 Ford F-100 Pick Up Custom calippincott Introduce Yourself 3 09-15-2006 08:15 PM
64 Ford Truck axle in a 34 Pick up??? teched Suspension - Brakes - Steering 1 12-23-2004 02:00 PM
