65 ford posi rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-29-2011, 11:06 AM
1965 mustang project
Last journal entry: what are these from??
i have a 302 putting out roughly 340 hp. i just bought a aod transmission for it.its a destroyer stage 2. i want to put a posi in the rear end with 3.55 gears. where can i look to purchase one ?? oh and what vehicles rearends are compatible with mine ???
Old 12-29-2011, 11:36 AM
BOBCRMAN@aol.com's Avatar
Summit or Jegs both sell posi units. You didn't say what 65 Ford you have!
Old 12-29-2011, 12:04 PM
In my '65 mustang, I bought it with an 8" rear and it already had posi/trac lock in it. I've heard the 8" will hold up to a lot of abuse, and I hope it does b/c my new motor is putting out 500hp and 475ft lbs. An 8" should be fine with 340hp. Only thing I've done is replace gears to 383s.
Old 12-29-2011, 12:27 PM
prostreet6t9's Avatar
Differential/Driveline
If you have the 8 Inch.
http://www.ringpinion.com/DiffWizard.aspx
Old 12-29-2011, 02:39 PM
hey bob, its a 65 mustang
Posi Rearend GMC R1500 Transmission - Rearend 7 01-01-2010 05:08 PM
What's it take to change my rearend to posi? batman09 Transmission - Rearend 1 12-03-2004 06:36 PM
scored a 9" Ford rearend now I need posi.unit shockers69 Transmission - Rearend 3 04-12-2004 10:26 PM
posi rearend robbysapien Engine 1 08-19-2003 11:34 PM
posi rearend ? inkfixer73 Engine 3 08-17-2003 12:47 AM
