65 Galaxie brake system - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2004, 05:36 PM
carpenter125's Avatar
I'm trying to change my master cyclinder from a single chamber to a double chamber. Does anyone know of one that will fit on with little to no modificaon? Also it has power brakes.
Old 04-21-2004, 12:29 AM
aka Duke of URL
Unhappy
Whew...
I don't know what to tell you about an exact bolt-on master. I have read that a mid eighties CROWN will bolt on to a manual system. But you have a booster with drums I assume. The master cylinder is going to have to from a later FORD/MERC with power four wheel drums.
Most likely a 67/69 GALAXY. You will also need the associated valving and plumbing. Sounds like a day in the donor yard doing comparisons.
You will be looking for mounting pattern and similiar push rod type.
