65 Galaxie power window kit - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2009, 12:04 AM
powerfiend's Avatar
Got a 65 galaxie convert that I want to upgrade to power windows. I was looking at one of those universal 'flat glass' kits and wondering if anyone has tried one of these kits:
electric life kit
I know they're designed for flat glass, but I think the galaxie glass is pretty flat.
Old 11-25-2009, 10:35 AM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
I have this in my 59
(well, an older version of the same regulater)
not likely that it will co-operate with any sort of a curve at all.
My 66 Elky has a very slight curve in the glass as well, and there is actually quite a bit of lateral movement with the bottom sash of the glass.
Have you considered looking into the late 70s Mercs or lincolns for something compatible??
Might be able to modify a regulator from a late Monte/GP/Regal to work.
Might try salvaging one of those to play with.
I would think once you got it to fit in the door----all you would need to do is to relocate the adusting cam slide.
Old 11-25-2009, 11:02 AM
Wiki Edits: 31
www.dearbornclassics.com has direct fit kits that will fit a '65 Galaxie
65 galaxie 65galaxie500 Suspension - Brakes - Steering 4 09-07-2011 03:19 PM
chevy lumina power window problem joe k Electrical 1 05-17-2009 05:12 PM
GM/Chevy Pickup power window switches Stinkin_V8 Electrical 6 01-24-2009 08:42 PM
Chev truck power window issue ghomer Electrical 6 01-05-2007 04:50 AM
Junkyard power window retrofit into 2nd generation Nova novajohnb Interior 4 11-16-2002 11:33 AM
