-   -   65 gto rear end swap (http://www.hotrodders.com/forum/65-gto-rear-end-swap-220449.html)
tin indian 06-12-2012 08:40 AM
does anybody know what will bolt right in.lookin for 8.5 :confused:
MRTS33 06-15-2012 03:35 PM
Technically A-body 64-72 will bolt right in. 64-66 are an inch narrower. 67 was a transition year. Some were an inch narrower some were not So I'm told). 68-72 were a inch wider and also had upper bars that were longer I believe.
Bryan59EC 06-16-2012 09:30 PM
Spring perches changed on the rear end for 67.
64-67 Cutlass, LeMans, Skylark, Chevelle.
These are all direct bolt ins except that you will have to use 67 springs on a 67 rear.
68-72 are an inch wider-----for these rears you will also have to use the 68+ springs.
Any of these rears will bolt in, but for the later ones you will have to keep a close eye on the wheel backspacing if you are running oversize tires.
tin indian 06-17-2012 07:10 AM
rear end
thanks for the info from you and everyone. i am on the hunt now.
TexasT 06-17-2012 11:15 AM
If you are wanting the 8.5, you need the 71-72 Cutlass or Skylark unit. These also have the advantage of bolt in axles. Plenty of parts unlike the earlier 8.2 axle at least in some of the variations.
LATECH 06-17-2012 11:36 AM
The 64 8.2 has smaller mounting ears on top of the housing. It will fit a 65, but to put a 65 rear (or newer) in a 64 the upper trailing arms need to be changed to the later years 65-66- +some 67 as the mentioned changes were in that year.The 65 -6-7 have a larger "hump" to clear the larger mounting bosses of the 65 up diff.
Trailing arms for the 68 and newer were a little longer, so it throws the pinion angle off.The differential mounts the same, so use the arms on the 65 that are there if you get a different rear, and it has arms on it, as delivered.
I realize the OP is working on a 65, just thought the info would be helpful to anyone else with a 64 in a similar situation. (like me) LOL
Remember too, after you install the rear, dont tighten the 8 bolts that mount the diff to the trailing arms and the frame.Tighten them AFTER the vehicle setting on the wheels and tires. Otherwise the mounting bushings start off being twisted too far and when you set the car down it will ruin them.Have the cars weight setting on the ground when you tighten all 8 bolts.Otherwise it will set crooked, moan, groan, pop and really suck. :boxing:
