65 gto rear end swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2012, 07:40 AM
does anybody know what will bolt right in.lookin for 8.5
Old 06-15-2012, 02:35 PM
MRTS33's Avatar
33 Pontiac 3W Sport Coupe
Technically A-body 64-72 will bolt right in. 64-66 are an inch narrower. 67 was a transition year. Some were an inch narrower some were not So I'm told). 68-72 were a inch wider and also had upper bars that were longer I believe.
Old 06-16-2012, 08:30 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Spring perches changed on the rear end for 67.
64-67 Cutlass, LeMans, Skylark, Chevelle.
These are all direct bolt ins except that you will have to use 67 springs on a 67 rear.
68-72 are an inch wider-----for these rears you will also have to use the 68+ springs.
Any of these rears will bolt in, but for the later ones you will have to keep a close eye on the wheel backspacing if you are running oversize tires.
Old 06-17-2012, 06:10 AM
rear end
thanks for the info from you and everyone. i am on the hunt now.
Old 06-17-2012, 10:15 AM
TexasT's Avatar
Did you ever wonder?
Last journal entry: A little follow up
If you are wanting the 8.5, you need the 71-72 Cutlass or Skylark unit. These also have the advantage of bolt in axles. Plenty of parts unlike the earlier 8.2 axle at least in some of the variations.
Old 06-17-2012, 10:36 AM
LATECH's Avatar
The 64 8.2 has smaller mounting ears on top of the housing. It will fit a 65, but to put a 65 rear (or newer) in a 64 the upper trailing arms need to be changed to the later years 65-66- +some 67 as the mentioned changes were in that year.The 65 -6-7 have a larger "hump" to clear the larger mounting bosses of the 65 up diff.
Trailing arms for the 68 and newer were a little longer, so it throws the pinion angle off.The differential mounts the same, so use the arms on the 65 that are there if you get a different rear, and it has arms on it, as delivered.
I realize the OP is working on a 65, just thought the info would be helpful to anyone else with a 64 in a similar situation. (like me) LOL
Remember too, after you install the rear, dont tighten the 8 bolts that mount the diff to the trailing arms and the frame.Tighten them AFTER the vehicle setting on the wheels and tires. Otherwise the mounting bushings start off being twisted too far and when you set the car down it will ruin them.Have the cars weight setting on the ground when you tighten all 8 bolts.Otherwise it will set crooked, moan, groan, pop and really suck.
Fact is stranger than Fiction
rear end swap 58chevy Transmission - Rearend 9 11-28-2010 09:52 AM
rear end swap coolcars58 Transmission - Rearend 4 08-14-2006 09:32 PM
rear end swap loosecannon39@yahoo. Transmission - Rearend 2 01-17-2006 01:09 PM
rear end swap john parks Transmission - Rearend 3 11-11-2003 01:47 PM
S-10 Rear End swap S10krazy Transmission - Rearend 0 10-08-2003 07:08 PM
