65' GTO... Swap to TH400 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2005, 04:04 PM
Last journal entry:
The tranny on my goat bit the dust at 150k miles. I was wondering what size Turbo 400 would fit my 65' GTO. It has the original 2 speed Super Turbine 300 behind the original 389.
I would really like to get my car back on the road.
Old 11-10-2005, 05:27 PM
BOBCRMAN@aol.com's Avatar
A 400 turbo will fit using all factory parts. You will need a turbo 400 short tail trans, BOP bolt pattern. A 400 crossmember for 66-72 Chevelle/BOP clones.. An electric kickdown switch/wiring for downshifts and a shorter driveshaft with a larger diameter front yoke.
Old 11-10-2005, 05:35 PM
Last journal entry:
Thanks Bob. I was hoping I wouldn't have to change out my driveshaft. What driveshaft will bolt up to this setup? Also, I am not familiar with the wiring for downshifts. Any input would be great.
Old 11-10-2005, 07:12 PM
A driveshaft from a later year (66-67) 400/GTO/442/GS should fit. You may have to use an oddball rear u-joint. They are available at any real parts store.
The 400 turbo does not use a mechanical (cable/rod) throttle opening sensor. On the OEM setup a switch was mounted on the throttle linkage to signal the trans (when the pedal was pushed down to pass/accelerate) to downshift.
t5 swap on pre '65 ford 289 flamedfordbronco Transmission - Rearend 2 10-25-2005 05:00 PM
74 to 65 rear end gear swap? 65_Chevy Transmission - Rearend 4 06-26-2005 01:29 AM
2004r to th400 swap screamin340 Transmission - Rearend 5 06-11-2005 07:50 AM
What's needed for a th350 to a th400 swap? Fil Transmission - Rearend 2 09-16-2004 02:09 PM
