65 impala disc brake swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2006, 03:07 PM
hi everyone,hopefully someone can help me shed some light on my situation,I recently purchased a set of disc brake spindles ( GM 3966187 CASTING #) calipers(5488316 GM casting #)and large rotors measuring 11 3/4 across with a stamping on it century R30003.This combination was supposed to be from an impala from 66-70,the problem I'am having is identifying the spindle because I did not get any spindle nuts dust caps or tab washers I thought it to be no big deal until I started to look for spindle nuts the spindles have the large outer bearing .850 which I was told to use but the thread is not the standar 3/4-20 size that I havefound to be common,the crest of the thread measures aprox. .850 and the root is aprox .800 the spindles seemed to bolt right on with no problem and look like they will align okay,also found another stamping number on the spindle (GM 72A) I'am thinking these might be from a Monte Carlo or other A body.if some one could help identifying these spindles it sure would help,I hope I haven't wasted a bunch of money trying to save some money,thankyou any info would be great
Old 07-26-2006, 04:07 PM
As far as I can find they are supposed to be off of a 1970 Impala?
1962 Impala disc brake conversion 62impala Suspension - Brakes - Steering 9 01-03-2014 07:57 PM
spindles on ford disc brake swap for 62 t-bird wildnickels Suspension - Brakes - Steering 3 03-20-2006 04:47 AM
Swap Drum to Disk Brake Ratoflic Suspension - Brakes - Steering 8 02-17-2006 11:24 AM
65 Impala Drum Brake Question EazyDuzIt102 Suspension - Brakes - Steering 1 10-21-2005 11:24 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
