65 Impala Transmission Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2005, 01:28 PM
EazyDuzIt102's Avatar
1965 Impala SS Convertible
I got a 65 Impala with a 400 Hydramatic transmission.I needed to replace the gasket on the pan.I bought the kit that comes with the Gasket and the transmission filter.When I took the pan off today I was looking in there and cannot find where the filter goes.Do I have to take something else apart after I get the pan off?Also,I was wondering what was the best way to install the gasket for the transmission pan?I just want to make sure I install it right.Thanks alot,
Eazy
Old 07-13-2005, 03:07 PM
On the first Picture I uploaded is what I think might be the filter that I pulled out of my transmission.The 2nd picture is what came with gasket I bought.The gasket fits the pan perfect.Is the thing in the first picture a filter?Any help would be appreciated.Thanks.
ID:	5768   Click image for larger version
Old 07-13-2005, 04:47 PM
The early 400's have a different filter than the later ones...1966 or 1967 was the changeover year IF I remember correctly.
The kit you bought came with the later one......
Your 400 can be converted but WHY ? ?
You just need a early filter.
DEUCE.......
Old 07-13-2005, 07:14 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
One item about the use of a late design filter in the early trannys..... your valve body ( if it is early unit) will NOT have a threaded hole for the late design filter retaining bolt.
The late design filter uses a shouldered bolt to hold the filter to the valve body...... although the filter will move a round a bit.
Second........ the late design filter uses a separate pick up tube with O-ring that goes between the case and the flat filter. This tube would NOT be in the gasket / filter kit you bought.
You may have to find a local tranny shop or parts supplier to purchase the early design filter for your t-400
looking for a bench seat for a 65 impala thegeckoj Interior 7 11-09-2009 08:42 AM
72 dodge dart transmission question A/G WILLYS Transmission - Rearend 4 05-08-2005 01:04 PM
Question on TCI transmission controller bugsdad Transmission - Rearend 5 03-31-2005 09:55 PM
65 Impala 327 Question EazyDuzIt102 Engine 3 02-27-2004 04:30 PM
transmission rear end for 65 chevy truck shortwide65 Transmission - Rearend 0 05-28-2002 08:37 AM
