65 Impala Turn Signal Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2006, 12:53 PM
EazyDuzIt102's Avatar
1965 Impala SS Convertible
I was wondering what it meant when the turn signal blinks really really fast?For some reason my turn signals dont blink normal anymore they are really fast.What could be the cause of this?
Old 03-23-2006, 04:22 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Usually Too much load on the flasher..(too many lights or an indirect short)
Or the flasher unit may be going bad..
Slow or no flash is too little current, or a light bulb is dead.
The flasher works as such, it has a tungsten contact inside it that heats up under the load of the circuit (light bulbs). (light on)
As it reaches top heat, it opens, reduces the load. (light off)
The tungsten cools down it then recontacts the load again..(light on)
This cycle goes on until power is removed.
Doc
Old 03-24-2006, 06:57 AM
What do you mean by "Too much load on the flasher"?What would be the main cause of that?
Old 03-24-2006, 07:38 AM
docvette's Avatar
Wiki Edits: 12
Originally Posted by docvette
Doc here,
Doc
Doc here,
That pretty much say's it....bad grounds, wrong bulbs..Corrosion in the sockets..
Doc
Old 03-26-2006, 11:54 PM
Might need a "heavy-duty" flasher unit. It's made for multiple lights on the circuit, such as trailering, or cars with multiple rear lights.
Turn Signal Short Theresa Shank Electrical 11 05-17-2005 08:43 AM
turn signal blowing flasher fuse RodFather Electrical 12 05-13-2005 06:23 PM
turn signal shortage texasfinest1 Electrical 2 09-16-2004 02:13 PM
How to convert to flashing hedlights instead of turn signal lights!! willys36@aol.com Electrical 5 08-11-2004 07:16 PM
Repairing turn signal switch Jag Daddy Electrical 0 06-17-2003 10:47 AM
