65 Impala turn signals dont work - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2009, 07:55 PM
I finally have all lights working except the turn signals. Went to check the relay and there is no relay mounted in the fuse box. Pulled the box from the fire wall and no wires mounted behind the box for a relay. How do I wire the flasher relay? Where are the wires located? If they are just gone, what wires shoiuld I use? The fuse box has no fastners mounted in it for the 2 wires, plus I see no wires to use to connect to the flasher. I am confused????
Old 02-09-2009, 09:05 PM
Baytonia,
Look for a plastic connector under the dash just to the left of the steering column. There are two wires coming to the connector, one is 12v with the key on and the other goes to the steering column and connects to the turn signal switch.
Good Hunting
Scholman
1966 Impala w/a '65 front end. Need advice. c-towndave Body - Exterior 1 01-02-2009 06:06 AM
Prelude led turn signals yeepman2 Electrical 1 06-26-2007 08:53 PM
Turn signals Chuck Q Electrical 8 06-01-2007 05:30 PM
Do I need dual filiment bulbs for turn signals? zachscc Electrical 3 03-09-2003 03:00 PM
turn signals impala dreaming Electrical 5 02-24-2003 06:29 PM
