65 impala wireing
65 impala wireing was mess all cleaned up but headlights stay on . but not the taillights .a/c - wipers only come on when headlights are turned on, not when parking lights on only but switch pulled all the way out thanks
also the fuse blows real quick Last edited by buckys65ssimpala; 06-19-2005 at 03:09 PM. Reason: to add that the fuse will blow quick |
hey there, when you say you had a mess, what do you mean? it sounds like your mess isnt cleaned up if nothing is working right.
i have a 66 impala which is just about the same. you can get a wiring diagram from any of the parts suppliers. then take it all apart and start over again. oh and welcome to the board. if you give a little more info i might be able to help you a little more. good luck.
Hopefully Doc don't mind
, this is a copy of the schematics he posted for my car, hopefully it can get you somewhere to start as I'm not sure how close your color codes will be to mine once again these are for a 67 Camaro. Hollar Doc if I'm steppin' on your toes and I'll remove your schematics.
Impala Wires
Doc here,
------------------------------------------------------------- Scott: No sweat on ANY of the Diagrams..That's what they are here For! If one Member can help another with Them, then By All means Please Do so! ------------------------------------------------------------- Bucky, WELCOME TO THE BOARD! I'm like REAL confused by your post...other than it sounds like you have the Harness from Hell...and may not have the right to exist in nature... OK, Lets see: If I read right, When you turn the headlights ON the wipers actuate? Dude...That's Just wrong... The Simple Class for GM wipers of that vintage is: Isolate the power Fuse for Wipers at the fuse buss... Run the protected side of that fuse to the wiper motor DIRECT... The Wipers on GM are wired "HOT IN RUN" at all times...Speed control and washer functions are controlled through the switch to GROUND...Not power.. The Color Codes for those wires Will (should be) : Yellow=12 volts from the fuse to the motor DIRECT no stops.. Light Blue:=Speed control 1 (and switchable ground) Black/org=speed control 2 (and switchable ground) White/Dark blue=Washer motor (and Switchable ground) The wiper motor has a ground pigtail itself that must be grounded also.. REMEMBER: All speed control and washer functions at the SWITCH are ground..NOT POWER..Hook it to power, and you'll end up with Fusus~inturruptus..The motor IS wired hot..Exact backward from the rest of the world.... That Should get those working... ----------------------------------------------------------------- HEADLIGHTS: They stay on like Forever?? what's the deal there..If that's the case you don't even have them wired to your switch..You need to pull the switch, and the harness and OHM it out.. First map out the configuration of your switch..Then center-wipers and Normally opens..Then transpose (using the above Schematic) those to The wire functions...That should get those working.. ---------------------------------------------------------------- Were it I, Personally, from what you describe, I would remove the harness from the car, and bench correct/wire it before trying to run with it..But that's just me.. Not trying to be an Educated Donkey ...(wise ***.. ) But do you have fuse links installed??????????That would be a VERY first priority Because Without them on a harness with that much past grafting..Is courting Disaster.. A good chance that it will go up in smoke, and start a HIGH CURRENT fire you will NOT be able to stop..(until the cable burns off..or the battery explodes from your rod burning down around it..) Links (if not there) FIRST, Then troubleshoot second... -------------------------------------------------------------------- Doc
Aftermarket Solutions Electronic & Electrical Innovations Last edited by docvette; 06-19-2005 at 05:28 PM. Reason: Bumbling Bigthumbitis... |
65 impala wireing
thanks doc what my problem is: when i plug in the main battery fuse, the headlights come on and stay, taillights and interior lights come on and work properly. the wipers and a/c still work by the headlight switch and the fuse gets hot and blows. thanks for the help, bucky
Ok...
Doc here..
Lets Do this one bit at a time... Just from what you describe..We'll do the headlights first, Somehow, When you hook up B+ Battery you are getting power to (using the below schematic) To either The Light Blue wire out of the headlight switch.. (to test this theory, switch on high-beams if they come on..then it's the light-blue wire) OR the Brown (Tan) wire on the headlight harness..(if no high-beam lights) Using a Volt ohm meter start at the brown (tan)wire at the headlights and back track for power readings to the switch..If you loose it at the high beam switch, look there for your short..you should find a power source that Should not be there...If so remove it and Test it again... The light switch seems to function properly, because if you look at the drawing below..all the other functions work..domes , tails, markers, turnsignals..(you said those worked right?) The ONLY wires that should have power on them with the headlight switch OFF are the ORANGE and RED wires.. Find and correct that problem first, Then we'll go on from there.. Doc
Aftermarket Solutions Electronic & Electrical Innovations |
| looking for a bench seat for a 65 impala | thegeckoj | Interior | 7 | 11-09-2009 08:42 AM |
| Drop springs for 65 Impala | misterwaterfallin | Suspension - Brakes - Steering | 3 | 10-03-2008 05:47 PM |
| Emblem help '65 Impala experts | zeus32100 | Body - Exterior | 7 | 12-18-2004 07:26 PM |
| 65 Impala Decoding? | robchris63 | Introduce Yourself | 1 | 11-05-2004 04:21 AM |
| 65 Impala Electrical Problem | EazyDuzIt102 | Electrical | 8 | 10-12-2004 06:31 AM |
