65 Mustang (1975 302) overheating promblem. Water pump question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2008, 11:07 PM
I have a 65 Mustang with a 1975 302 motor. I used the stock 289 water pump and radiator. My question is: Does it matter that the water pump on the 302 originally had the inlet on the drivers side and I used the early 289 water pump with the inlet on the passenger side. I could not use the 302 water pump because it would not work with the radiator. Does the later 302 motor flow water in a different direction or is it the same as the old 289.
Any info will help.
Old 06-21-2008, 03:53 AM
im not sure if that matters or not. have you checked the thermostat? put it boiling water to see if it opens. try running the car w/o it in. did you flush the rad. before you put it in, maybe thats plugged up. when you have the thermo stat out fill the block with water first then put your fill neck on then fill the rad could have been air locked
Old 06-21-2008, 11:31 AM
Any info will help.
NO problem at all. Should cool as well as a 289.
I suggest a shroud and a 7 blade fan and thermostatic clutch if possible, the 65 cars were marginal coolers when new.
Old 06-21-2008, 11:57 PM
JeffB's Avatar
Any info will help.
The reverse flow pumps came out in 1985,so you are OK
Old 06-22-2008, 11:45 AM
Thanks for all the help
BBC Water pump Question JamesRS Engine 8 08-02-2007 01:56 PM
Water pump rotation question djenn Engine 6 03-07-2004 10:04 AM
power steering from long water pump to short water pump kellyem Suspension - Brakes - Steering 7 02-22-2004 07:22 PM
Water Pump Question Kaylah Engine 11 08-22-2003 09:35 PM
water pump question Tissue Engine 2 06-11-2003 08:52 PM
