www.discbrakeswap.com if you can't find a Granada locally... the Ford Granada swap is the most common. they came in V8 and I6's and the stuff is a lot easier to get than the Kelsey Hayes stuff... a Granada or Maverick rear will work, but the original rear 'might' be a 4 lug 8", because part of the '65 year, the 6cyl Mustangs got the 4 lug 8" instead of the more common 7 1/4" 4 lug 6cyl rear
mustang disc
there are a couple of sites that deal with mustang and smaller fords. .fairlanes falcons comets ,etc/ you will find more info there... some 6 cyl maverics also had 5 bolt wheels with front disc's ...I think they are the same parts as granada-monarch- lincoln versailles... The granada calipers tend to wear off one side of the rotors. you need to keep the sliders lubed. One of the ford sites had instructions on using the new mustang GT calipers on the granada type cars. the brackets looked easy to build at home. 80's lincoln town car rear disc's are supposed to be easy to convert to the rears. I picked up lincoln and cad eldorado rear disc pieces when I was helping a friend who owns the local wrecking yard. I haven't tried to do a ford or gm conversion yet. too many other projects to do first.
Guessing what this Mustang disc rear end is.
Cheers Mustang Al.[ |
mustang disc
there are kits out there to do a new crosmember and use the mustang II components. Mustand II had small brakes. there are conversions to upgrade to 11 inch or larger rotors ..the mustang II spindles are front steer. the rack in ftont. Granada-monarch versailles came stock with 11 inch rotors. get a speedway catalog and check out all the things you could do. there are brackets to use granada-mon-vers calipers on the mustand II spindles but Gm is the most popular. I'm still up north, will being going south next week. The shop with most of the cars is 400 miles south. sometimes I go to NAPA auto parts on line and try to match up parts. I have a stock mustang front suspension with the KH 4 piston brakes. missing 1 caliper bracket. the bracket is very hard to find. and a set of 40 ford spindles with the 4 p KH conversion and an old magazine article on how to do it. there is a new conversion offered with 4 piston calipers . big $$$ ...If you google mustang forums you will find quite a few forums dealing with just ford products and lots of info
| 66 Mustang front brakes | 66-351 | Suspension - Brakes - Steering | 3 | 09-18-2006 07:16 PM |
