65 mustang rack and pinion conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-06-2002, 06:36 PM
New Member
Question 65 mustang rack and pinion conversion
i have a 65 rag top and i want to put a power rack and pinion, does anyone know what rack i can use? i want to mount it to the cross member bar under the engine, i will have to weld bosses to the bar to bolt the rack on,i was told that if i dont get the geometry right the wheels will toe out on a major bump, any ideas or suggestions?thanks
Old 12-06-2002, 08:16 PM
aka Duke of URL
Arrow
-Total Control Products-
Old 12-07-2002, 01:52 PM
woodz428's Avatar
Troll Hunter
Arrow
Besides Total control products, which makes some neat early Mustang stuff which is kind of pricey, you could get a crossmember to put the whole MII suspension under it as cheaply and eliminate all the shortcomings of the early suspension.
Old 12-08-2002, 02:18 PM
deuce_454's Avatar
Post
a rack from a 80's GM j, car can be mounted in a classic 60,s ford. here is a page with pics and howtoos: <a href="http://home.pacbell.net/ssixto/automotive/R&P/HowTo.html" target="_blank">Click Here</a>
