'65 Rambler American engine swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2008, 09:24 AM
Wiki Edits: 31
I have a '65 Rambler American with a 196 6cyl/ Auto. The engine is extremely tired and in need of a rebuild ( which I'm not going to bother with ). even though it starts easy, it uses a lot of gas and it smokes a lot ( blue, so I know it's blow-by as it never goes away ). I want to swap to a modern V8, preferably a Ford 302.. I know the BW-M35 trans ( what it has now ) uses most of the same internals as the BW derrived Ford FMX trans.. would the Rambler X member fit a FMX trans? I'm not worried about modification but if I don't have to, that would be awesome. The car is a daily driver so the least I have to worry, the better
Old 06-18-2008, 04:10 PM
FEDDO's Avatar
just what I would do ,is locate a late model 5.0 with the aod trans, and go from there.
Old 06-18-2008, 04:39 PM
you will also need a true driveshaft and a different rear end. Rambler Americans had torque tubes and they are very weak. But, when you get that car done, it should be pretty quick due to it's low weight. Also, post some pictures
Old 06-18-2008, 05:03 PM
Wiki Edits: 31
'64 Up Rambler Americans have open driveshafts, no torque tubes. '58-'63's did have torque tubes. If it was a torque tube I wouldn't bother.
I was actully thinking along the lines of a Crown Vic donor car for the engine/ trans.
Old 06-18-2008, 07:10 PM
FEDDO's Avatar
that would work. i used an 88 t bird, and changed to a carb. I used lokar trans linkage for the tv hookup.
Old 06-18-2008, 07:51 PM
Wiki Edits: 31
The junk yard I go to is a u pull it littered with crown vics.. but anything 302/AOD I will pull if it's good... less than $300 trans and engine togther from that yard.
Old 06-18-2008, 08:34 PM
I stand corrected
Old 06-18-2008, 08:38 PM
Wiki Edits: 31
The rear end/ drive shaft does use a really weird pinion nut that is diffrent from normal cars. but that's not really a problem, as I'll just give the driveline shop the old 1 so they can salvage the end to make the new 1
Old 06-21-2008, 06:05 PM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
The only problem with using the original axle and driveshaft is the tiny universal joints. The axle is 7-9/16", and strong as a Ford 8", so it's okay for a stock 302 in a light car. If you put very big tires on and drop the pedal hard, the u-joint will break before anything else. 8" street tires (about all that will fit the wheel wells anyway) should be okay with normal driving, but keep a spare universal joint on hand. It will last a while, but how long I don't know. Those joints were used on Fords with the 200 six, but I think the 250 six cars used a bigger joint. No way to put a bigger joint on the original axle. That axle is narrow, but a Chevy S-10 (and probably Ford Ranger) axle will fit with a little work.
Old 06-21-2008, 08:21 PM
Wiki Edits: 31
I'm keeping everything stock on the new engine/ trans. and keeping the rubber the stock size all the way round.
Ford 200 I6 cars came with a 71/4" rear end from 1960-1969 ( 8" after ), and the 250 cars came with a 8" or an odd 8.8" in 1978-1979 in some Mercury's. 1 of my other cars is a '67 Falcon 6cyl but I'v never changed the U joint on it... Didn't know they used the same joint as the Rambler
Old 06-21-2008, 10:45 PM
SSedan64's Avatar
Hey Farna is the Union Switch & Signal Co. still in biz in Batesburg? Used to work for them.
rambler american engine swap bnsurvey Engine 3 11-30-2011 05:10 PM
53 Packard Clipper Engine Swap? 53packard Engine 16 07-06-2010 05:32 PM
Engine Swap Help KACHINA321 Engine 15 03-02-2007 09:15 AM
v6 Engine Swap millennium Engine 3 04-29-2004 03:50 PM
Engine swap gcusick Engine 7 11-14-2001 04:11 PM
