'65 rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2005, 07:36 PM
chevelle_502's Avatar
Get out the ducktape...
Last journal entry: Front brakes
Wiki Edits: 5
'65 rearend
My buddy's got a 1965 chevrolet pickup 2wd with a 3 speed and an inline 6. The truck is shot but Im just curious to know what the gear ratio might be in the rearend. If anyboy knows what it might be or how to find out Id appreciate it.
Thanks fellas
Old 03-08-2005, 08:03 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
If there is a stamped axle ID number, it should be on the front of the passenger side axle tube between the differential housing and the spring perch.
You may have to use a scraper or wire brush to see the stamped number/letter combination, the first part of the combo is the axle ratio itsself.
65 mustang rearend tonylsg Transmission - Rearend 5 04-12-2003 10:40 AM
Looking for suggestion of rearend Shefron Transmission - Rearend 0 03-23-2003 11:23 PM
rearend for a Model A 30coupe Transmission - Rearend 10 11-25-2002 08:04 PM
measurments for a rearend 50chevyfastback Transmission - Rearend 2 10-04-2002 12:19 PM
