65 riviera rear axle seal replacement - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2004, 07:36 AM
jartzh's Avatar
My axle is leaking at the wheel. This is the rear end without an inspection plate on the differential. Any experience replacing the seal? Local shop wants $200 per wheel.
Old 10-08-2004, 11:35 AM
As one of the Moderators here.......let me be the first to WELCOME you here.
You remove the wheel/tire/rim and then the brake drum.
Remove the 4 bolts that hold the axle in (to the backing plate).
Then use a axle puller and pull the axle. Then you can replace the seal. New wheel bearings are a great preventive maintenance move also.
Reverse the procedure.
DEUCE ......General Rodding Tech Moderator.
Old 10-08-2004, 12:42 PM
jartzh's Avatar
Thanks,
Can I replace the seal without removing the bearings? I would think I would have to press the bearings off/on. If so then do I need a shop to do that?
