65el camino front suspension to low ?
I put 13 inch Bear Brakes with 2 inch drop spindels with air ride and 18 inch wheels with 40 series tires and with out the front clip or motor in the front crossmember only sits 2 and half inchs off the ground with the bags full is this height sound right ?
2 1/2" with full bags, no front clip or engine, you are way too low.
would anybody know what i can do to solve this prob ?
do you have your heart set on the 40 series tires?
you may have go to standard spindles |
I would check the angle of the lower control arm, if they are parallel with the ground then higher profile tires and/or stock spindles. If they are higher at the ball joint than the inboard mounting point, get taller bags.
Thanks for all the help found out I had the wrong size bags just bought new ones
| 74 el camino brakes & suspension | the other Mick | Suspension - Brakes - Steering | 2 | 09-07-2009 03:02 PM |
| 72 El Camino Suspension Advice | Skaughty | Suspension - Brakes - Steering | 0 | 04-16-2009 03:31 PM |
| SS El Camino suspension upgrade | stinky jinx | Suspension - Brakes - Steering | 2 | 06-02-2004 01:53 PM |
| El Camino suspension ride | stinky jinx | Suspension - Brakes - Steering | 0 | 05-29-2004 12:09 PM |
| el camino suspension?? | mac95 | Suspension - Brakes - Steering | 1 | 01-15-2003 09:54 AM |
