66 bronco rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2011, 07:16 AM
Last journal entry: done as of 9/10/08
66 bronco rearend
i hope some one can help me out.
i have a 66 bronco with a clunking noise in the rear end and a hesitation, can feel some thing is holding the bronco back for a second. it will happen as the rotation is completed to the same spot.
i can hear the noise on the passenger side in the rear.
could it be a bearing? or a brake shoe ?
thank you for all the help in the past, and i hope some one can direct me to what to look for with this problem.
again thank you
Old 04-11-2011, 12:26 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
It could be either one. Jack the rear up & pull the wheel, Might just be the brake lining or a piece of the lining, came off one of the brake shoes.
Rich
Old 04-11-2011, 01:59 PM
thank you for the reply i will try to check it out as soon as i can
Old 04-11-2011, 02:35 PM
Wiki Edits: 31
yep. sounds like a brake lining issue.. could also be a leaky axle seal. that will cause the brake lining to soften and expand/ grab. but you would see a mess when you pulled the drum
Old 04-14-2011, 05:03 AM
thanks for the help i will pull the drum and see what is going on
again thank you for the help
rick
Old 04-25-2011, 05:27 PM
it turns out to be a bearing, and i am having one heck of a time trying to pull the axle out i have a slide hammer but still don't seem to want to break loose.
any idea's on how to remove the axle please let me know
Old 04-26-2011, 11:24 AM
Hi
I think you may have an 8.8 rear as the axles in the 9" slide right out. However an 8.8 has C clip retainers.
jack the rear end up, put drain pan under rear end & remove the cover. look in at the center of the differential & you'll see a big pin in the middle, as you turn the drive shaft you'll see there's a 12 point 5/16 bolt on one end. Remove that bolt then push the pin out (must be pushed from inside out to be able to get it out). (If/when you spin the tires now the spider gears and shims will fall out. Not a big deal) Push the tire in , it will move about a 1/4 of an inch, now look at the end of the axle where that big pin was & you'll see a big C clip on the end of it, it should push right off. Now you can slide the axle out.
Good luck
Rich
Old 04-26-2011, 03:23 PM
got it out it is a 9 inch big bearing axle, had a kid stop by and help me today he just got behind where the wheel studs (plate) and hit it with a big hamer and pry bar 3 times and out it came, the bearing was totaled ball's where falling out of it so i guess it was time to change it LOL
anyway thank all of you that helped me out here
have a good one and take care
again thank you
Old 04-26-2011, 05:56 PM
Hi Rick
Glad you got it out, & thanks for the update.
Rich
Old 04-26-2011, 07:45 PM
Rick,
If I were you I would replace the other side also. You are there and I am sure it will be near the end of it's life too.
Also change the gear-lube just to be sure there is no metal flakes in the other bearings inside the third-member.
Scholman
Retired
Old 04-26-2011, 09:51 PM
Scholman, Good call.
Rich
78-79 bronco rearend options. Rubberman2003 Transmission - Rearend 5 07-26-2008 08:11 AM
7 1/2 ford bronco rearend grapro Transmission - Rearend 1 10-14-2006 07:37 PM
Bronco II fordfun Introduce Yourself 3 05-07-2006 11:36 PM
Bronco Rearend HotRodS10 Transmission - Rearend 1 02-11-2004 05:56 PM
429 into 83 bronco Jared Engine 1 11-22-2003 06:32 PM
