66 bronco trans and transfer case - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-10-2011, 01:21 PM
Last journal entry: done as of 9/10/08
hope some one here can help me out again.
i have a 1966 bronco that had a std transmission in it and they replaced it with a auto. trans.(before i bought it ) now the problem is the transfer case fills up with transmission fluid when i have to add some to the auto. trans. is there some kind of return line from the transfer case to the auto trans.?
any help would be great. the trans. keeps loosing fluid and the transfer case keep over filling itself.
thank you in advance for any help
Old 09-10-2011, 02:17 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I am reasonbly sure there is supposed to be a seal between the trans and transfer case..have to pull the combo and see..might be helpful to find a tech manual for that..
Sam
Old 09-10-2011, 05:07 PM
thank you for the help i will see if i can find one. could i just pull the transfer case and put the seal in and replace the transfer case? (transfer case meaning the whole gear box)
Old 09-10-2011, 05:14 PM
LATECH's Avatar
Yes, it is that simple.Just be sure to install the seal correctly.The side with the spring inside the lip goes toward the trans.check the fit on the transfer case stub to be sure the diameter is correct.
Old 09-11-2011, 03:52 PM
would this mean that there are 2 seals leaking ?
the transmission fluid is going into the transfer case.
this setup is a conversion it has a auto. trans it used to be a standard trans.
it also has some kind of adapter in behind the auto trans and before the transfer case.
Willys Wagon Trans+Transfer Case MOtorPARts Transmission - Rearend 2 04-27-2011 01:35 PM
Trans Fluid Between It and Transfer Case? slydelon Transmission - Rearend 1 06-11-2010 07:51 PM
Transfer case not going on. Raybob Transmission - Rearend 10 12-15-2008 07:27 PM
Mopar 727B car trans bolt up to 4x4 transfer case MOTOR HEAD Transmission - Rearend 1 03-16-2008 10:35 PM
th 400 to b-w transfer case gm3bud8 Transmission - Rearend 0 12-13-2002 02:05 PM
