66 caprise elec seat operstion issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2012, 09:49 AM
elec front seat. makes a clicking noise on what looks like a relay but nothing moves. makes noise in any position. has 3 sets of wires that plug into it. is there a way to test it or by pass relay to see if seat works?
thanks Butch
Old 08-09-2012, 12:43 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Moving on to electrical...
Sam
Old 08-09-2012, 08:42 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
test
I do not have a wiring diagram for that model but there are some tests you can do.
Locate the power wires (2) that connect to each motor.
There may be more than (2) wires going to each motor. You can identify the power wires by observing the size of the wire. generally the larger of the wires will be the power wires.
Select one of these motors and briefly apply 12 volts to the wires. (1) wire ground and the other wire + . The frame of the motor need not be connected to anything.
Observe the rotation and motion of the seat. For example; seat runs forward. Then reverse the polarity of these same (2) wires. The seat should run in the reverse direction.
If all the motors function as expected the seat motors and mechanical gears are OK.
Also you may want to test the seat under a load by simulating operating in the condition installed with a person sitting on it.
vicrod
elec,wire duster75 Electrical 4 11-22-2011 04:58 AM
Best 60s Issue of Hot Rod Magazine and best 50s Issue of Car Craft MXrider13 Hotrodders' Lounge 18 07-29-2011 01:55 PM
vacuum issue or carb issue idk for sure chevyok06 Engine 1 07-10-2011 05:19 PM
Bench Seat Swap To Bucket Seat Help arnellwest Hotrodding Basics 11 03-28-2011 10:50 PM
10-12 Bolt U-joint Issue Issue MrB Transmission - Rearend 3 09-29-2007 08:17 AM
