66 chevelle rear bushings - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2006, 02:54 PM
What are the best bushings to buy. The car is used mostly on the street , once in a while at the strip.Where's the best place to buy.thanks
Old 09-24-2006, 05:36 PM
rj57's Avatar
Polyurethane really can be the better choice over OE rubber replacement bushings. You may think with Urethane costing more then rubber, the rubber is the better choice here. I can tell you rubber can deriorate over time without even being used. I've got a couple of A-arms I had new rubber bushings pressed into so years ago that dissolved just from setting. The A-arms were never put back into service. And I know of other's who've testified to the same.
If you lube Urethane bushings when you re-assemble you can relieve the nasty squeaks people say they get with Urethane.
Old 09-26-2006, 09:05 AM
Nobody has ever done this?
Old 09-26-2006, 06:59 PM
elcamino72's Avatar
Gearhead
I would recommend urethane ... the rubber bushings will dry up and crack before you know it.
'66 Chevelle rear into a '69 69novarodr Transmission - Rearend 3 10-04-2005 06:22 PM
Should I buy? 66 Chevelle dougi66 Hotrodding Basics 7 08-16-2005 09:07 AM
66 chevelle rearend swap SBC4ME Transmission - Rearend 3 06-18-2005 07:35 AM
71 Chevelle rear control arm bushings 454me Suspension - Brakes - Steering 4 04-23-2005 09:46 PM
Rear Bushings??? spoodlmeyer Suspension - Brakes - Steering 1 03-10-2004 10:44 PM
