'66 Chevelle rear into a '69 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-03-2005, 11:47 PM
Chevy stuff makes a Ford Tough
my brother has a '69 Chevelle with a stock 10 bolt rear (a 2.73 peg leg) and stock suspension. He found a '66 Chevelle that has a 10 bolt posi 3.42 and stock suspension and was wondering if the it would swap into his car. He said the '66 Chevelle's rear is an inch narrower, but wasn't sure if it was from drum to drum or in spring location.If you have any info on the swap, please let me know. Thanks in advance for any replies.
Old 10-04-2005, 06:35 AM
It should bolt in......the width difference is from drum to drum.
Be sure to change the speedometer gear also....
Old 10-04-2005, 04:42 PM
MI2600's Avatar
Member# 3287
I've got a '67 rear in my '72 and it fits ok. They apparently changed the rear widths in mid '67, as you said to about an inch wider.
Old 10-04-2005, 06:22 PM
thanks for the help guys. We're planning on goin and checking out the '67 soon to swap rears.
How To lift The Rear Of A 69 Camaro JimKramer Suspension - Brakes - Steering 4 09-16-2005 04:14 PM
72 chevelle rear ends 406chevelle Transmission - Rearend 10 02-15-2004 10:22 PM
will 66 or 67 chevelle rear end fit dragrace87 Transmission - Rearend 1 07-21-2003 10:56 AM
69 chevelle disc brakes 87 350monteSS Suspension - Brakes - Steering 4 07-17-2003 07:33 PM
66 Chevelle Rear Suspension Stan Roberts Transmission - Rearend 1 10-31-2002 09:08 PM
