66 chevelle rearend swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2005, 10:18 PM
New Member
Can anyone tell me if A 10 bolt rearend out of a 71 olds cutlass SX would fit in my 66 chevelle? and if so would it require any special fabricating.My 66 has 4 trailing arms ,2 lower and 2 upper.
Old 06-17-2005, 08:41 AM
Hippie's Avatar
Last journal entry: HEI comparison.
1971 right? It will bolt up OK but is 1-1/2" wider so you'll need to watch your wheel backspacing very closely but it will work. The rear U-joint may or may not be different so check that. I know it was on the B-O-P 8.25" 10 bolts but a '71 Olds could also have an 8.5". A '73-up won't bolt up without some work.
Old 06-17-2005, 02:13 PM
New Member
re:66 swap
Thanx for the info. Yes it is a 1971 olds. Is the OLDS rear end (which is a 10 bolt with posi)a stronger rear end than my 66 10 bolt? I plan on rebuilding whichever one I end up with but if the olds rear end is not a better one then I might juts keep it and add the posi.The olds had a 455 in it.
Old 06-18-2005, 07:35 AM
Hippie's Avatar
There is a possibility of 2 different 10 bolts in a '71 Olds Cutlass, the 8.25" B-O-P axle which had bolt-in axles (or at least everyone we ever opened up did) and the 8.5" Corporate 10 bolt which had just come out. In '68-'70 Olds also used on oddball that was a 10 bolt with a 12 bolt cover, very hard to find aftermarket gears for but a decently strong rearend. With a 455 I'm betting on an 8.5". Either one is stronger than your 8.2" Chevy 10-bolt but the 8.5 is by far the strongest of the 3. The 8.25" BOP's are a little harder to find parts for now but not impossible.
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 01:32 AM
rearend swap for a nova nova63and66 Transmission - Rearend 10 11-10-2005 06:34 PM
66 el camino 66 c-10 rear end swap? Echofive Transmission - Rearend 0 01-30-2004 10:47 PM
66 chevy rearend swap with corvette daddyj Transmission - Rearend 2 01-02-2003 09:21 AM
