66 chevy pickup wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2005, 06:20 PM
I have a project 66 pickup into which someone dropped a later model (69-80 per the casting #s) 350 with alternator attached; I wired it according to the original 66 diagram but that doesn't account for the generator/external voltage regulator to alternator switch; also, I have no power to the ignition switch but am able to crank the engine with an external starter button.
What's the best source for info on properly wiring this setup - do I need a different harness or just bypass the regulator? Just wading into this mess - any help will be appreciated.
Old 10-04-2005, 07:51 PM
docvette's Avatar
Wiki Edits: 12
Wire
Doc here,
Here is the diagram for the Alternator:
And one for the start system:
If your Ignition system is dead, the "Hot at all times" wire is dead, It should be pink or purple 10 gauge...It will go to the main bolt on the starter solenoid (the battery cable terminal) Via a fuse link...
The same applies to the red 10 gauge wire from the alternator via fuse link..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 10-04-2005, 08:18 PM
thanks
Doc-
Will climb back under the hood at first opportunity with your diagrams in hand. Thanks.
whats the difference between 55 and 56 chevy pickup? mile-hightoyz Hotrodding Basics 8 08-13-2011 10:33 AM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 11:00 PM
59 Chevy pickup frame woes! Li'l Pine Suspension - Brakes - Steering 33 07-08-2009 09:24 PM
1947-1955 Chevy pickup spotter's guide willys36@aol.com General Rodding Tech 2 02-14-2004 11:28 AM
engine wiring diagram (92 350 c.i. chevy pickup) dunegoon Engine 2 12-15-2002 02:46 PM
