Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 66 chevy rearend swap with corvette
Old 01-02-2003, 08:14 AM
zachscc zachscc is offline
Should be easy if you have your old rear end for maeasurments. Go to Sears and buy a $10 Angle finder and then put the old rear axle on two jack stands with a jack under the pinion to allow you to rotate the axle on it's center then adjust untill you old perches are level (with a level) and take a measurment off the back of the cover mounting surface to determin what up or Down angle you need for the new perch pads. You can buy weld on perch pads at or speedway also has bolt ons if you can't weld but they cost about $50 Call the 800 # and talk to the speedway guys dirrect there parts guys are brilliant!
