unless the Poisson of a v-8 engine mount has changed on block he should be able to get a set of mounts, also if its a BB Chevy had the option for a BB in those trucks so he could get BB mounts easily also. as far as tranny, there are custom trans mounts where you cut out the old cross member and weld in a new one with the right mount, and the rear end i would assume would fit, not sure on that, take lots of measurements, make sure its not to wide or anything. the computer stuff, well, thats prolly going to take a good deal of re wiring and know how of how it all works. one other thing is your probably gona have to get a custom drive shaft, iv stated most of the obvious things, some one with a lil more knowledge could help more probably.
