Thread Tools Search this Thread share on Facebook
  #1
Old 08-05-2011, 05:20 PM
car boy 68 car boy 68 is offline
66 coronet
How do you put a MSD distributor in a 66 Coronet that had points. How would you wire the MSD distributor without a 6AL box?
Register now (free) or login to remove ads
Old 08-05-2011, 07:54 PM
mmopar0521 mmopar0521 is offline
Last wiki edit: How to make a custom dashboard
Last journal entry: Front end getting near complete
Wiki Edits: 4
Depending on the distributor, the install will be a little different, but any distributor without points is going to require a spark box of some kind. Don't know what you have invested, but the MSD box is probably your best bet.
Old 08-05-2011, 09:58 PM
Centerline Centerline is offline
Wiki Edits: 49
I always use a Mopar electronic distributor with the orange box. Haven't had one fail yet.
Centerline
HotRodsAndHemis.com
"Horsepower sells cars, Torque wins races." – Carroll Shelby
Old 08-06-2011, 01:15 AM
matt167 matt167 is offline
Wiki Edits: 31
Centerline
HotRodsAndHemis.com
Yep, and most of the guys who do that swap on B bodies mount the orange box under the battery tray. the distributors use the same cap, so it all looks stock from above.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "66 coronet"
ThreadThread StarterForumRepliesLast Post
coronet introcoronetIntroduce Yourself1304-12-2011 12:51 AM
coronetjefferiahHotrodding Basics706-21-2010 12:34 PM
59 CoronetKGB45Introduce Yourself108-07-2007 07:51 PM
54 coronet Day 1Magnus_JagerHotrodders' Lounge209-26-2003 06:48 PM
Superbee or Coronet?slpnmhHotrodders' Lounge109-20-2002 05:01 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
