66 cuda rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2005, 11:58 AM
66 cuda rear end
My son cuda has a 7 1/4 rearend.If i wanted to swap it for a 8 3/4 rearend,is there any car out there i can use its rearend without much changing spring perchs.Thanks
Old 05-18-2005, 04:26 PM
Wiki Edits: 49
The 8 3/4" rear was also found in V8 "A" bodies prior to '72 as well as larger "B" bodies and most pickups. Check your track width and head to the wrecking yard. Most "A" bodies will have the 7 1/4" rear but the high performance versions will usually have the 8 3/4" version.
Look for:
66-67 Barracuda with 273, 4 bbl carb and 4 speed (probably Formula S)
67 Barracuda with 383
68-69 Barracuda (318 with standard trans)
68-69 Barracuda (340 or 383 standard or auto)
68-72 Dart and Valiant with HP V8
70 Barracuda or Challenger
Good luck.
Old 05-19-2005, 05:23 AM
cuda66273's Avatar
The 66 was a narrow A-Body or referred to as an "Early A" the rear end width is 2" narrower than 67 and up A bodys.
A 8.25 rear end from any A body will bolt in but wheel offset becomes an issue especially if you use the 4 on 5 bolt pattern. Try and find a 8.25 with 4.5 on 5 pattern, wheels are easier to find.
While you have it out get the relocation kit and move the springs 3" in, this will allow for bigger and more tire/wheel options.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
66 nova rear end robbysapien Transmission - Rearend 5 08-01-2007 07:48 PM
Best way to raise the rear end on 66 Nova? frankenvette Suspension - Brakes - Steering 2 05-13-2004 01:36 AM
Front end lift 66 cuda street rodder 1937 Suspension - Brakes - Steering 1 05-06-2004 07:46 AM
anyone running 700r4 with 3.55or 3.77 rear end? 37 chevy Transmission - Rearend 7 01-06-2003 06:34 AM
