66 el camino - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2012, 01:11 PM
66 el camino
powerglide trany is leaking out through the splines through the yoke. Can't firure out why. Any ideas?
Old 12-22-2012, 01:41 PM
delawarebill's Avatar
leak'n
bad seal...
Old 12-22-2012, 02:18 PM
he's right bad rear seal easy fix just drop the drive shaft and pull it out remove old seal and put in a new one and replace drilve shaft. any tranny shop can do that in no time flat.
Old 12-23-2012, 10:16 AM
cranky1's Avatar
Just stuck
If it's leaking through the splines, you can change all the seals you want and the leak won't stop. It's most likely the cap or welch plug in the back of the yoke leaking. You'll need to pull the yoke off the u-joint to get to it. Either replace the yoke or clean it and seal the plug.
Old 12-23-2012, 03:25 PM
pricesgarages's Avatar
proble worn bushing or yoke
72 el Camino Zumpy72 Introduce Yourself 5 10-13-2010 03:55 PM
El Camino 1979 Camino Introduce Yourself 2 08-19-2008 08:45 PM
el camino alecatalecat2 Introduce Yourself 3 07-28-2008 09:35 AM
my el camino ss downtempoking Engine 3 07-13-2005 09:15 PM
71' El Camino sscamaro_510 Engine 6 12-09-2004 01:56 AM
