66 El Camino steering pump issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-03-2010, 02:04 AM
truckboy61's Avatar
I'm switching out My 327 that has power steering and replacing it with a 454 in my 66 el Camino and do not have the power steering brackets for the BB. I was thinking of using a hose to place on power steering box so fluid will continue to circulate ? Will this work if not any ideas on how to handle it ? If I should chose to leave it off will there be long term issues?
Old 07-03-2010, 05:33 AM
poncho62's Avatar
Wiki Edits: 5
Not having the pump with a PS system makes steering very stiff.....would be almost impossible to drive.......You need to have a pump or put a non power steering box on it.
Old 07-03-2010, 01:06 PM
truckboy61's Avatar
The pump and belt are completely off and it feels like typical non power steering, however fluid pumps out turning either direction? And there is no motor in at this time I assumed after placing the BB in the weight would increase difficulty ?
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Which waterpump? Eagle1 Engine 5 08-06-2004 06:38 PM
Power Steering for 1959 El Camino w/348 bigfred1958 Suspension - Brakes - Steering 0 05-17-2004 09:48 PM
power steering from long water pump to short water pump kellyem Suspension - Brakes - Steering 7 02-22-2004 07:22 PM
66 el camino 66 c-10 rear end swap? Echofive Transmission - Rearend 0 01-30-2004 10:47 PM
