66 f100 turn signal wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2011, 07:07 PM
chlsnk's Avatar
"Love what you do for a living
I replaced the turn signal switch because I had no turn signals at all. Now all my signals work. The fronts are correct but the rear signals light up opposite of what they should be. It has a rats nest of wiring from the past owners. Does anyone have a wiring diagram for the wiring off the column?
Thanks.
Old 04-28-2011, 11:50 AM
vicrod's Avatar
life is a ride
Last journal entry: LED tail lights
The wire colors should match on both sides of the steering column connector.
Also check the wire colors at the rear TS lights to see if they match the colors at the steering column connector.
Somewhere these wires are flipped.
vicrod
Old 04-28-2011, 01:17 PM
Here's a diagram for a 64 I found on FTE.
brake light and turn signal wiring slammed 57 Electrical 4 10-28-2009 06:25 PM
turn signal wiring problemoo Blackhauk90 Electrical 4 09-30-2008 08:20 AM
51 Merc turn signal switch wiring curtis73 Electrical 10 05-22-2008 06:42 AM
Yankee Turnflex Turn Signal Wiring n3ffn Electrical 7 02-01-2006 04:26 PM
Yankee Turnflex Turn Signal Wiring kingcaddy Electrical 4 07-14-2005 09:00 PM
