66 ford fairlane 289 crank no start - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2012, 02:32 PM
was driven sat for awhile, no start. found sombody had played with lock cyl/ ignition. Replaced, now engine cranks has no spark. has power at coil (pos) when key turned on, and when cranked. no spark from coil(new coil) cleaned connections on starter solenoid. I did find black wires under starter solenoid terminated on bridge(secured w/2 screws under and aft a little of starter solenoid secured to inner fender) broken. could this be issue???very very open to suggetions.
Old 04-29-2012, 03:12 PM
LATECH's Avatar
Sounds like trouble with the points.
Have you checked them?
Fact is stranger than Fiction
Old 04-30-2012, 08:09 PM
Thank You for the reply, this is a little new to me. all I have had has been HEI never really need to worry about this type of ting. My father said the same thing. so I took a peek. there is no gap, so I adjustetd so I had opening and closing. I think the gap is supposed to .017 (not Sure) but there was none and now there is some. I also took a screw driver while contacts wre open and grnded with key on. I did get spark but not alot. there is some rust on distrib shaft. was gonna get a feeler gauge to varify gap? I know im missing something basic...but I am. I'm really gratefull for the time. Thanks.
Old 04-30-2012, 08:47 PM
Wiki Edits: 27
dwell meter
Feeler gage will get you close , to get best results I always used a dwell meter, I still have points in the T bucket and on the 2- 4 chevy because of hei space problems
Old 05-01-2012, 06:19 PM
LATECH's Avatar
.017 is a good place to start. That will get you in the ballpark , and as long as the points arent burnt up, it should fire the coil.
Try that first then post back.
5 speed manual into a 1967 Ford Fairlane with 289? my52 Transmission - Rearend 7 07-27-2008 12:05 AM
289 with a 351 crank? pi71 Engine 26 07-05-2007 04:41 PM
big fairlane, 289, need more hp brooksy9 Hotrodders' Lounge 22 09-18-2006 03:35 AM
302 or 289? Which will be best to replace the 6 cyl. in my '65 Fairlane? jdox Engine 7 10-20-2005 04:02 AM
1965 Ford Fairlane 289... go a little faster? killerformula Engine 29 04-07-2004 08:08 AM
