66 heads on 74 454? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2006, 11:51 PM
smac's Avatar
66 heads on 74 454?
I'm considering buying a '74 SS 454. The current owner tells me he has '66 heads on the stock '74 lower end. Says he has to run a mix of racing fuel and premium to keep detonation down due to the 10.5:1 compression...
Does this sound right to any of you BBC guys out here?
Maybe its a common mod, I dont know much about BBC's (yet)
I was really hoping for a stock '74 454 that I could wake up with intake, cam and exhaust and still run cheap pump gas.
Thanks,
Sean
Old 02-15-2006, 12:18 AM
1939beast's Avatar
Wherever you go, there you are
They are probably closed chamber heads. Pull the valve cover and check the #s. They make high compression at the cost of poor flow.
Old 02-15-2006, 12:58 AM
techinspector1's Avatar
Wiki Edits: 326
The problem that you'll encounter with any of the motors from '72 up until EFI is that the compression ratios were dismal and squish was non-existant due to the excessive deck height. If you are going to add a little soup to one of these motors, you really should tear it down and correct the deck height / squish. You'll find if you do, that you'll have no trouble running pump gas at up to 11:1 with iron heads and a cam that matches the c.r. (squish at 0.035" to 0.040").
Old 02-15-2006, 05:06 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I'm a BBC fan and I don't mind telling you that BBC head's chambers are pathetic at best. The chamber shapes don't do a darn thing for swirl or quench compared to modern heads. 10.5 on 66 heads sounds like 100+ octane to me.
I'm running 8.6:1 on my 454 and I had to carefully tune my ignition curve to prevent detonation on cheap fuel. Modern aftermarket BBC heads have solved that issue, but old-school iron BBC heads don't cut it. Swap those old heads for some newer castings... even 049s and you'll get much better performance and octane tolerance.
Old 02-15-2006, 05:55 AM
Bumpstick's Avatar
Hammer and a torch
Nothing can be figured till you know what heads and what pistons are being used... While all the mentioned info is good things have to be considered... What are you going to use this engine for...? If you want fuel economy forget it... If you want performace then use the higher compression and its advantages... But first find out exactly what you have...
Why spend money on heads? F-1Rodder Engine 8 03-07-2008 01:09 AM
Chevy Big Block 454 Marine heads 71 nova Engine 4 09-03-2004 07:08 PM
Heads novatech Engine 10 01-17-2004 02:27 PM
AFR Heads DTL504 Engine 9 12-09-2003 03:55 PM
L98 IROC/TA/Formula heads? dirtlmfan Engine 2 02-17-2003 01:02 PM
