66 impala disc brake conversion help - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2005, 08:42 PM
helrazr3's Avatar
im on a highway to hell
Last journal entry: new wheels and seats
i need some help, i,m planning to upgrade to disc brakes and i went to the KB and there was an article in there on 66 impala upgrade.but alas the page is now gone i searcher the guys web site and e-mailed him but no response. the problem is that i want to keep my 14"wheels. the thread listed a bracket set that bolted to the stock spindles and used some camaro or chevelle stuff but i don't know who sells the bracket kit and exactly what parts to use. does anyone know who makes them and have a complete parts list for it? i checked the relevant threads in the KB but the company wasn't mentioned there any help would be appreciated
thanks rich.
Old 03-24-2005, 06:49 AM
66Caprice's Avatar
Move It On Over!
I don't know if this will help or not, but I've been eyeballing these guys:
Master Power Brakes
Their kits let you bolt the disc brake to the original drum brake spindles.
Old 03-24-2005, 04:14 PM
helrazr3's Avatar
thanks, i think thats what i was looking for sort of. i found the bracket kit but theres no info on rim size or what gm parts to use i'll have to dig around a little more. thanks .
Old 03-24-2005, 09:47 PM
helrazr3's Avatar
i found the site and the kit if any of the moderators want to put this link in the KB here it is www.classicperform.com it has the bracket kit and the list of parts you use to complete the swap.
Old 03-25-2005, 09:00 PM
I converted a '69 Nova to discs with factory parts, & the 14" wheels rubbed on the calipers. I used a 1/2" steel spacer on each side of mine & it worked OK. I have also used OEM 14" wheels from later Novas that were factory disc cars & they cleared fine without spacers.
All '75-up Novas & '70-up Camaros had discs from the factory, and have the same bolt pattern as yours. Malibus too, but I don't know what year they went to discs.
Old 03-26-2005, 07:17 AM
helrazr3's Avatar
thanks jim, thats interesting what vehichle did you get your parts from? its seems to me that mid 60's b-bodys and early 70's a and f-bodys shared the same stuff. the funny thing is i have no idea what aplication my cragars are so im going to cross my fingers. btw did you make the spacer yourself or does someone make it?
thanks again.rich.
Old 03-26-2005, 06:46 PM
Corvette brakes
We used Corvette disc brakes on a low-budget stock car....the Corvette spindles pop right onto the '66 Impala control arms...
If you keep the stock rear drums you'll need a proportioning valve....If you use a dual master cylinder off a later model GM car, you can plumb in the Corvette adjustable valve....or use the valve off whatever GM car you get the master cylinder from...make sure if it isn't adjustable, that the donor car had front discs and rear drums....
Old 03-27-2005, 11:43 PM
Novas & B-cars are definitely different. '65-'70 B-cars have basically the same front suspension as each other, & discs were available '67-'70. '67-'68 used 4-piston calipers, which are somewhat rare, prone to leakage, and have marginal aftermarket parts availability. '69-'70 use the common & reliable single-piston calipers.
I first used some 1/4" aluminum spacers from a famous hot-rod parts company whose name begins with "M". They collapsed, & one front wheel got swallowed by a wheel well. Sparks, noise, etc. I had some individual bolt spacers (ten, in all) made from 1/2"-thick steel plate & they worked much better. If I had it to do all over again, I'd use wheels that were made for discs, because with spacers, your wheel may not be exactly centered on the hub.
Ford Galaxie Disc Brake Conversion CrashFarmer2 Suspension - Brakes - Steering 5 04-10-2010 04:52 PM
Rear Disc Brake Conversion for '73 Impala hduff Suspension - Brakes - Steering 11 10-22-2004 03:34 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
Disc Brake Converstion on my 66 Impala trick66 Suspension - Brakes - Steering 1 03-23-2003 03:14 PM
