Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 66 impala front wheel bearing
Old 04-21-2013, 05:06 PM
NEW INTERIORS NEW INTERIORS is offline
life is a temporary assignment
I snug them down to make sure to suck them up,,, Then back off until it just turns freely and then put the cotter pin in.. You don't want them too thight or too loose... Thight enough that it turns freely.. Hope I explained this where you can understand what I'm getting at..
When it's done you should be able to spend the rotor.. If it's too thight,, You can burn them up.... I seen some guy's thighten them so much you can't turn them.. And tell you they have to be that thight...
Make sure you put the cotter pin back in place...
Some people may do it different,, This is the way I do it..
