66 impala front wheel bearing - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2013, 04:05 PM
Hey all I need to replace my front wheel bearings on my 66 impala, so my question is how do I set the preload/rotating torque on these bearings? Thanks.
Old 04-21-2013, 05:06 PM
life is a temporary assignment
I snug them down to make sure to suck them up,,, Then back off until it just turns freely and then put the cotter pin in.. You don't want them too thight or too loose... Thight enough that it turns freely.. Hope I explained this where you can understand what I'm getting at..
When it's done you should be able to spend the rotor.. If it's too thight,, You can burn them up.... I seen some guy's thighten them so much you can't turn them.. And tell you they have to be that thight...
Make sure you put the cotter pin back in place...
Some people may do it different,, This is the way I do it..
Old 04-21-2013, 08:08 PM
poncho62's Avatar
Wiki Edits: 5
I do it the same.....
Old 04-21-2013, 08:18 PM
I also like to hand pack my bearing the old way..
Old 04-21-2013, 08:53 PM
Faith - Respect - Trust
X2 on what everyone has posted...including hand packing the bearings...a tip for getting the proper tension on the bearings is to spin the rotor or drum while your tightening the bearings...this helps to center them and gives you a good indication as to when they have enough pre-load.
Ray
Front Wheel Cylinders On a 67 Impala BowTiePride Suspension - Brakes - Steering 11 12-17-2014 03:51 PM
Front wheel bearing/hub mitmaks Suspension - Brakes - Steering 3 10-28-2012 09:45 PM
Front wheel bearing question Don Lyon Transmission - Rearend 3 07-28-2008 08:50 PM
Proper Front wheel bearing torque Tonythefish Suspension - Brakes - Steering 7 01-29-2007 02:28 PM
Tri5 front wheel bearing replacement Stroker56 Suspension - Brakes - Steering 3 04-14-2006 06:36 PM
