66 impala stock Rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2008, 10:03 AM
I wan't to put a Posi Rearend in a 1966 Impala Sedan. Right now it has a 406 SBC with a Turbo 350. Can anyone point me the right direction as far as what type of Rearend came in a 1966 Impala? I know it's a 10 bolt.. I would just like any help finding out what's in it now? And a good choice what to put in it? Cost? Dimensions?
Thanks
Cixty6
Old 08-07-2008, 11:27 AM
Probably an 8.2"
There are aftermarket posi carriers available.
Old 08-07-2008, 07:47 PM
cowbay's Avatar
Thanks
Cixty6
You sure it is not a 12 bolt rear? If it is there are many manufacturers to go with from strange, moser to powertrax
Old 08-07-2008, 09:02 PM
SSedan64's Avatar
If you're sure it's a 10Bolt, it will be an 8.2" Ring gear Diff with 28 spline axles. You can get an 8.2" Posi such as these, the (Powertrax) is for use in the Open type carrier to convert it to a Posi, sort of like a minispool as such you don't have to remove the carrier & gears to do it>
http://store.summitracing.com/egnsea...115+4294790783
I'd try Ebay for a better price. Or if you could find a 12 bolt Rear housing it will be easier to find a Posi carrier used or new.
Look at this link and it will show what will interchange into the 10 & 12 Bolt housings, from which vehicles, gear ratios etc.. Pg.72 & 73.
http://books.google.com/books?id=ztA...y5RzI#PPA72,M1
66 Impala turn signal switch assembly black66 Electrical 5 12-10-2010 06:07 PM
64 Impala rearend disc brake conversion Bad Rat Suspension - Brakes - Steering 3 07-02-2008 11:05 PM
66 impala disc brake conversion help helrazr3 Suspension - Brakes - Steering 7 03-28-2005 12:43 AM
66 Impala 530 HP SBC black66 Introduce Yourself 1 10-12-2004 03:04 AM
Wiring in a 66 Impala black66 Electrical 9 07-09-2004 09:23 AM
