66 impala wiring issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2012, 08:44 PM
can anyone tell me where to check for a fault i had very dim dash lights but now no tail lights or dash lights and the fuse is not blown i replaced the headlight switch and ensured proper contact but its not resolved , i bypassed the switch on the plug itself and the rear taillights work fine which tells me the problem is between the dash and headlight switch or column any help is much appreciated thanks
Old 08-12-2012, 09:25 PM
Dennis W. Parks
Have you verified that you have a good ground for your lights? Electricity is weird that it will run through the path of least resistence. To diagnose electrical problems, you really need a multimeter or voltmeter so that you can verify where you have 12 volts and where you don't.
Dennis W. Parks
Author of automotive how-to books
The Following User Says Thank You to WriterDennis For This Useful Post:
66impalaman (08-13-2012)
Old 08-14-2012, 03:44 AM
EOD Guy's Avatar
Try hooking a temp jumper between a good ground and the headlight switch ground, sounds like you've got a bad dash ground.
alternator wiring issue. 56dodge Electrical 4 08-19-2010 06:02 PM
64 Impala SS - Door Closing Issue 64Joker Hotrodding Basics 2 12-23-2009 03:52 PM
Chevelle BB wiring issue!! tempestwagon64 Electrical 7 05-23-2009 01:31 PM
Calling the DOC..66 Impala headlight switch issue black66 Electrical 7 06-01-2006 03:46 PM
wiring issue gilby246 Electrical 2 03-20-2006 09:57 PM
